Heat Balance Algorithm input in HB Energy
Hello chris I think this can be solved by a simple python battery, I replaced the Solar disturition parameter by this battery.
import os
Input variables
idf_file_path = x
old_content = y
new_content = z
Open the IDF file and read its contents
with open(idf_file_path, ‘r’) as f:
file_content = f.read()
Replace the specified content with the replacement content
new_file_content = file_content.replace(old_content, new_content)
Get the file name and directory of the input IDF file
idf_file_dir, idf_file_name = os.path.split(idf_file_path)
Generate the output file path by appending “_updated” to the file name
output_file_path = os.path.join(idf_file_dir, idf_file_name.split(‘.’)[0] + ‘_updated.idf’)
Save the updated file contents
with open(output_file_path, ‘w’) as f:
f.write(new_file_content)
Output the path to the updated IDF file
a = output_file_path
