Hi @MingboPeng,
Sorry to bother you, just wanted to know if it is possible to simulate air-to-water HeatPump into Ironbug ?
Thank you in advance
Hi @MingboPeng,
Hi @Ardian,
I think it has been challenging to model air-to-water heat pump in EnergyPlus. I doubt that you can model it directly in OpenStudio/Ironbug. If you check the unmet hours, there are several workarounds: https://unmethours.com/question/17410/heating-pump-air-to-water/
https://unmethours.com/question/26950/modeling-air-to-water-heat-pump-with-fan-coil-unit/
