I would like to set up heat recovery and demand controlled ventilation with the new version of Honeybee.
But I can not find the component or a new component with the above mention inputs. (see picture)
Any suggestions for improvement are more than welcome.
Thanks a lot Erikbeeren. I went trough also the sample file as you suggested on my other post but I could not found how to change cooling and heating details of a HVAC system. COP, supply temperature etc.
Do you know where I can find it?
Most HVAC templates come with standard settings. These templates are designed by Matthew Dahlhausen from Openstudio. If you want build your own HVAC detailed HVAC system you can use Ironbug or the openstudio app.
With Ideal airloads you can set the heating and cooling temperature:
