Hi I am trying to calibrate a model to hourly electricity bills (and monthly gas bills). It seems like my modelled electric boiler is cycling on and off much more than the real one. Are there settings in ironbug to make the heating system less sensitive? Thanks
I would suggest comparing the model’s loads with your bills first and calibrate it before applying a real system.
The HVAC system response to the model’s loads, if you get the loads match the bill’s patten, then you can get the HVAC system works more or less like what you have in the bill.
