Hello, I have tried this component. Is the parameter of “Air Flow Rate” in it from the architectural design standard?For example, if indoor ventilation is set at least 2 times per hour, is that the option corresponding to the above “air flow rate”?Or does it correspond to wind speed m/s?
As per my knowledge the ventilation change (2 times or 3times) per hour is termed as Air Change per Hour (ACH). If the 2 provided by you represent ACH then supply True to the input _ACHorM3sM2. Else, supply False for the same input if it is 2 cubic meter per second per square meter of air flow rate
