During the energy consumption simulation, EnergyPlus did not work properly and the model was not closed, but when the HBZone interface was connected, the panel showed that the model was closed…Excuse me, where is the problem that I hope someone can help me answer it
Here are two problems it shows:
- The simulation has not run correctly because of this severe error:
** Severe ** For zone: XI_NING it is not possible to calculate the volume from the surrounding surfaces so either provide the volume value or define all the surfaces to fully enclose the zone. - The simulation has not run correctly because of this severe error:
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
I’m going to upload my original file. Can someone help me? I haven’t figured out the problem myself.Thank you!!!
xining.gh (884.4 KB)
