following Chris’ tutorial 17:
https://www.youtube.com/watch?v=OWeoXlQyPxg&index=18&list=P…
two window constructions are created: doublePane and singlePane, and they are assigned to different zones using the Set EP Zone Construction component.
However, when using Label Zone Surface with EnergyPlus Construction option of the surface attribute lists component, the window construction is still the default exterior window.
May I ask where I did wrongly?
Thanks!
tut_17_ZJ_v001.gh (647 KB)
