Aha.I was not aware that it works only with 8.1.Or may I knew that and forgot…Will install 8.1. and see what happens.
This is the report: it has 4 warnings 49 severe errors
Analysis period is from 1 JUN to 31 DEC
Between hours 1:00 to 24:00
Current document units is in Meters
Conversion to Meters will be applied = 1.000
[1 of 7] Writing simulation parameters…
Ground temperature data contains monthly average temperatures at 3 different depths .5 meters (1st)2 meters (2nd)4meters (3rd)respectively
[2 of 6] No context surfaces…
[3 of 6] Writing geometry…
[4 of 6] Writing materials and constructions…
[5 of 7] Writing schedules…
[6 of 7] Writing loads and ideal air system…
[7 of 7] Writing outputs…
… idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf
Analysis is running!..
c:\ladybug\unnamed\EnergyPlus\eplusout.csv
Done! Read below for errors and warnings:
Program Version,EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2015.05.24 11:32,IDD_Version 8.3.0
** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
** Warning ** Version: in IDF="‘8.1.0’" not the same as expected=“8.3”
************* Beginning Zone Sizing Calculations
** Severe ** GetSurfaceData: Some Outward Facing angles of subsurfaces differ significantly from base surface.
** ~~~ ** …use Output:Diagnostics,DisplayExtraWarnings; to show more details on individual surfaces.
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=“APRATMENT1”
** ~~~ ** because vertex 1 of back surface=AW0 is in front of receiving surface=EW0
** ~~~ ** (Dot Product indicator=17.0963)
** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
** ~~~ ** because vertex 2 of back surface=AW0 is in front of receiving surface=EW0
** ~~~ ** because vertex 3 of back surface=AW0 is in front of receiving surface=EW0
** ~~~ ** (Dot Product indicator=17.1101)
** ~~~ ** because vertex 4 of back surface=AW0 is in front of receiving surface=EW0
** ~~~ ** because vertex 1 of back surface=AW1 is in front of receiving surface=EW0
** ~~~ ** because vertex 2 of back surface=AW1 is in front of receiving surface=EW0
** ~~~ ** (Dot Product indicator=30.0900)
** ~~~ ** because vertex 3 of back surface=AW1 is in front of receiving surface=EW0
** ~~~ ** because vertex 4 of back surface=AW1 is in front of receiving surface=EW0
** ~~~ ** because vertex 1 of back surface=AW2 is in front of receiving surface=EW0
** ~~~ ** because vertex 2 of back surface=AW2 is in front of receiving surface=EW0
** ~~~ ** because vertex 3 of back surface=AW2 is in front of receiving surface=EW0
** ~~~ ** because vertex 4 of back surface=AW2 is in front of receiving surface=EW0
** ~~~ ** because vertex 1 of back surface=AW3 is in front of receiving surface=EW0
** ~~~ ** because vertex 2 of back surface=AW3 is in front of receiving surface=EW0
** ~~~ ** because vertex 3 of back surface=EW1 is in front of receiving surface=EW0
** ~~~ ** because vertex 4 of back surface=EW1 is in front of receiving surface=EW0
** ~~~ ** because vertex 1 of back surface=GLZ_0_EW1_1F6383543B434F648813 is in front of receiving surface=EW0
** ~~~ ** (Dot Product indicator=0.9038)
** ~~~ ** because vertex 2 of back surface=GLZ_0_EW1_1F6383543B434F648813 is in front of receiving surface=EW0
** ~~~ ** because vertex 3 of back surface=GLZ_0_EW1_1F6383543B434F648813 is in front of receiving surface=EW0
** ~~~ ** (Dot Product indicator=16.0967)
** ~~~ ** because vertex 4 of back surface=GLZ_0_EW1_1F6383543B434F648813 is in front of receiving surface=EW0
** ~~~ ** because vertex 6 of back surface=FLOOR is in front of receiving surface=EW0
** ~~~ ** because vertex 7 of back surface=FLOOR is in front of receiving surface=EW0
** ~~~ ** because vertex 8 of back surface=FLOOR is in front of receiving surface=EW0
** ~~~ ** because vertex 9 of back surface=FLOOR is in front of receiving surface=EW0
** ~~~ ** because vertex 5 of back surface=CIELING is in front of receiving surface=EW0
** ~~~ ** because vertex 6 of back surface=CIELING is in front of receiving surface=EW0
** ~~~ ** because vertex 7 of back surface=CIELING is in front of receiving surface=EW0
** ~~~ ** because vertex 8 of back surface=CIELING is in front of receiving surface=EW0
** ~~~ ** because vertex 3 of back surface=AW6 is in front of receiving surface=EW1
** ~~~ ** because vertex 4 of back surface=AW6 is in front of receiving surface=EW1
** ~~~ ** because vertex 1 of back surface=WALLW1 is in front of receiving surface=EW1
** ~~~ ** because vertex 2 of back surface=WALLW1 is in front of receiving surface=EW1
** ~~~ ** because vertex 3 of back surface=WALLW1 is in front of receiving surface=EW1
** ~~~ ** because vertex 4 of back surface=WALLW1 is in front of receiving surface=EW1
** ~~~ ** because vertex 1 of back surface=GLZ_0_WALLW1_103854D39BEF453D8A4E is in front of receiving surface=EW1
** ~~~ ** because vertex 2 of back surface=GLZ_0_WALLW1_103854D39BEF453D8A4E is in front of receiving surface=EW1
** ~~~ ** because vertex 3 of back surface=GLZ_0_WALLW1_103854D39BEF453D8A4E is in front of receiving surface=EW1
** ~~~ ** because vertex 4 of back surface=GLZ_0_WALLW1_103854D39BEF453D8A4E is in front of receiving surface=EW1
** ~~~ ** because vertex 1 of back surface=EW0 is in front of receiving surface=EW1
** ~~~ ** because vertex 4 of back surface=EW0 is in front of receiving surface=EW1
** ~~~ ** because vertex 1 of back surface=GLZ_0_EW0_6AEDE94222384E5B8950 is in front of receiving surface=EW1
** ~~~ ** (Dot Product indicator=1.4709)
** ~~~ ** because vertex 2 of back surface=GLZ_0_EW0_6AEDE94222384E5B8950 is in front of receiving surface=EW1
** ~~~ ** because vertex 3 of back surface=GLZ_0_EW0_6AEDE94222384E5B8950 is in front of receiving surface=EW1
** ~~~ ** (Dot Product indicator=15.6696)
** ~~~ ** because vertex 4 of back surface=GLZ_0_EW0_6AEDE94222384E5B8950 is in front of receiving surface=EW1
** ~~~ ** because vertex 1 of back surface=FLOOR is in front of receiving surface=EW1
** ~~~ ** because vertex 2 of back surface=FLOOR is in front of receiving surface=EW1
** ~~~ ** because vertex 2 of back surface=CIELING is in front of receiving surface=EW1
** ~~~ ** because vertex 3 of back surface=CIELING is in front of receiving surface=EW1
** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
************* Testing Individual Branch Integrity
************* All Branches passed integrity testing
************* Testing Individual Supply Air Path Integrity
************* All Supply Air Paths passed integrity testing
************* Testing Individual Return Air Path Integrity
************* All Return Air Paths passed integrity testing
************* No node connection errors were found.
************* Beginning Simulation
************* Simulation Error Summary *************
** Warning ** The following Report Variables were requested but not generated
** ~~~ ** because IDF did not contain these elements or misspelled variable name – check .rdd file
************* Key=*, VarName=ZONE PACKAGED TERMINAL HEAT PUMP TOTAL COOLING ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE PACKAGED TERMINAL HEAT PUMP TOTAL HEATING ENERGY, Frequency=Hourly
************* Key=*, VarName=CHILLER ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=BOILER HEATING ENERGY, Frequency=Hourly
************* Key=*, VarName=FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VENTILATION FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VENTILATION TOTAL HEAT LOSS ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VENTILATION TOTAL HEAT GAIN ENERGY, Frequency=Hourly
************* There are 1 unused schedules in input.
************* There are 1 unused week schedules in input.
************* There are 3 unused day schedules in input.
************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
************* EnergyPlus Sizing Error Summary. During Sizing: 1 Warning; 49 Severe Errors.
************* EnergyPlus Completed Successfully-- 4 Warning; 49 Severe Errors; Elapsed Time=00hr 00min 4.59sec
Thanks Abraham.I really appreciate it.
Another thing ’ I posted a discussion few days ago and got no replies.And this forum is the only ‘Hope’ for me…Can you quickly check it?thanks.
N
http://www.grasshopper3d.com/group/ladybug/forum/topics/free-form-e…
