After running the Annual Daylight Simulation I’m not getting any result… the RESULT Output is empty
Before, with the grid-based simulation and climate-based sky, it worked perfectly
Does anyone have an idea regarding the subject?
Thanks!
Thanks!
Hello @minggangyin,
Yes, i have DAYSIM 4.0 on my computer.
Again, other simulations work perfectly, I have only trouble with the ANN simulation, no result in the output.
Any other idea?
Thanks for the help!
@LovelyRita Here is a example created by @chris. You can run it on your computer.
Honeybee_Annual_Daylight_Simulation_Example.gh (524.1 KB)
Hi @minggangyin,
Thank you so much!! actually, it solved my problem!!
Thank you so much for your time!!!
I have another issue maybe you can help-
How can i assign layer from Rhyno model (Window, doors etc…) into a grasshopper code?
Thank you so much for your kindness!
L
Thank you @minggangyin
Do you have any idea how to add interior walls for the calculations?
somehow the code works only for the skin
Thank you so much
