Why does UDI low and up data always be empty?
Maybe because all grid points are inside the UDI limits?
No. No matter how I set the threshold of -lt and -ut , it still appears empty.
I’ve known it’s a bug. Thanks
Yes, it’s a bug that was fixed soon after the release. There’s currently a small bug in the development version of the plugin so I recommend going to version 1.2.5 with the Versioner if you need the fix right away. The latest development version should be fixed early this week.
