Honeybee 3DM & test points data structure
hi @devang
here it is, thanks
TestFiles
Thanks a lot for trying this @OlivierDambron. I patched it. You can try now. Attached are hbjson and csv I generated. The hbjson has one sensor grid object for the grid layer that you have in the file. Use this link to download the generated files.
Here’s the image exported from an html generated using honeybee-vtk
HI @devang
sorry for the late reply, it’s competition season…
I’ve succesfully installed the new patched version of honeybee-3dm.
However, the csv is generated empty. I’ve tried to simplify the geometry to make simple tests and the bug remains.
Hey @OlivierDambron,
Did you forget to supply the config file?
There we go! Thanks so much @devang , with this I can do all I need, reconstruct my points following a logic and match the data structure.
Let me know if you prefer that I keep the fork to clear your repository or if you’re good like this.
I assume the point generating function in honeybee-3dm is the same as honeybee in grasshopper?
On grasshopper, I often encounter issues such as :
Or
I’ve tried switching tolerances up and down and it’s quite unpredictable.
Is it fair to assume honeybee-3dm behaves similarly?
Not exactly same implementations but both the LBT grasshopper plugin and honeybee-3dm use Ladybug Core libraries undet the hood.
Don’t worry about it. I will maintain my branch until you ask me to delete it.
It should be the same as the point-generating Grasshopper component when you set quad_only_ to True. When you set it to False or leave the default, the component will use Rhino’s meshing agorithm.
