Hi Mostapha,
Can you please elaborate more on upOrientation input of Honeybee_Radiance BSDF component. I already looked at the PDF you referenced in the component. I think, I am still not very clear on. How to correctly set the Orientation vector. I am running a simulation using attached file. When I run illuminance analysis, the result makes it look like I am simulating a plane glass.
I am running a simulation using attached file. The material is applied to a totally horizontal skylight. When I run illuminance analysis, the result makes it look like I am simulating a plane glass.
Devang
Okalux_Kapipane_20_klems.xml (209 KB)
