Hi there,
I’ve been trying to generate an illuminance analysis on just site and the effect Im trying to get is that the mesh would ultimately replace the gridanalysis component as the new grid. I’ve checked everything but not sure why the analysis doesn’t work at all?
Thank you!
Chung
BasicIllum.gh (948 KB)
I m not sure what you are trying to do. Do you mean you are trying to view the result on the rhino window?
and just looking to your image you need to set write and run to True.
Hi Mostapha,
I’ve set write and run to True and received error msg that reads ‘cannot evaluate gradient with zero-length range’ and i’ve checked the illumance value with panel - do you think that where the problem is?
