In my HB energy model, I have two interior walls (that do not have windows), two exterior walls, and two interior floors (floor and ceiling). However, as you can see in the image below, all of the walls are assigned to exterior walls, the floor is the exterior floor, and the ceiling is seen as the roof. How can I assign them properly? I need to properly assign these building components because in the construction sets and modifier sets, info about these components is required. The only thing that comes to my mind is that I can model other adjacent rooms and then solve adjacency? Any tip, technique, and method would be appreciated.
B_Blok_2_Daylight_EnergyIncluded_2_GlassTrial_2_Faces.3dm (51.4 KB)
B_Blok_2_Daylight_EnergyIncluded_2_GlassTrial_2_Faces.gh (177.1 KB)
