Hi
i have a light-well through a multi story building. i want the light can pass through its extension, but Honey bee can not distinguish it. in other word, honeybee can not solve the intersection between ceilings. however i had used the solve adjacency
which part of algorithm i did wrong?
unnamed.gh (121.1 KB)
Hey @Aliarch ,
You would ideally need to try setting the air boundary
input to True
between the light-well and the room.
You can additionally use HB Properties by Guide Surface to override the adjacency.
Check out this discussion as well.
Cheers,
Adarsh
