Honeybee cannot find a compatible LBNL THERM installation
Hi, all!
I just started using HB recent days, and I encountered a problem while opening a gh file I downloaded from the forum. The screenshot is attached below.
The issue is I have already installed Therm 7.6 (and Therm 7.7 after seeing the warning), but it didn’t work.
Also, I chose the default path when installing Therm (which is under C:\Users\Public\LBNL), hope that won’t cause any problem.
Thanks in advance for all answers and help!
I noticed the HB you are using is the old version, that maybe the issue.
I hade the same file path as yours, so that should not be problem for running Therm 7.6.
Hi David!
Apologize for the terribly late response. Indeed the new version has solved the problem.
Thanks!
