hy mostapha, i’m nubie with grasshopper …how if i just change this script v8-1-0 with v8-4-0? actually honneybee can recognize that file, but can you tell me what kind of problem can generated with that??
Hi Moose! I haven’t checked the updates in EnergyPlus 8.4. There might be some issues in loading the results as they may have changed output names. Otherwise it’s usually fine. If you update Ladybug and Honeybee the latest version works by EP 8.3 by default.
Hi Dani, The error is because the component cannot create a new folder under Ladybug default directory. Can you change the default folder for Ladybug similar to how you’re doing it for Honeybee? That should solve the problem.
