Hi, quick question on how often I should run a simulation when working through schematic options.
Up until now, I have been running a new simulation for every different window configuration. However, I just noticed even that if I change the geometry without running a new simulation, then the surface energy accurately updates too.
Is this an acceptable workflow or will I incur some issues down the line with accuracy or other things? It would be a real time saver for me if this is possible, especially during early schematic/conceptual when things are loose.
Here are some screenshots showing window changes, but using the same .csv file:
Components:
