Hi, I had the same issue on Rhino 7 (IronPython,2.7.12.0,C:\Program Files\Rhino 7\Plug-ins\IronPython\IronPython.dll),
but not for Rhino 6 on the same machine (IronPython,2.7.8.0,C:\Program Files\Rhino 6\Plug-ins\IronPython\IronPython.dll)
But rather than trying to fix, I instead just did the following, which will work if you don’t need method1 uuid generation which relies on obtaining the MAC address of a machine.
Basically copy the UUID class from uuid.py along with the three mehods uuid3, 4 and 5 and the namespace constants. (NOTE: most implementations of uuid generation use method 4)
"""Provides a scripting component.
Inputs:
x: The x string to be hashed
y: The y string to be namespaced (currently not an input as this hardcodes the standard DNS namespace into the def for uuid3 and 5)
Output:
guid3: Method 3 guid result
guid5: Method 5 guid result
Remarks:
__author__ = 'Ka-Ping Yee <ping@zesty.ca>' a simplified version of the uuid library that solely depends on hashlib as other libraries were causing errors in IronPython grasshopper"""
__author__ = "JulesBuh"
__version__ = "2022.04.26"
RESERVED_NCS, RFC_4122, RESERVED_MICROSOFT, RESERVED_FUTURE = [
'reserved for NCS compatibility', 'specified in RFC 4122',
'reserved for Microsoft compatibility', 'reserved for future definition']
class UUID(object):
"""Instances of the UUID class represent UUIDs as specified in RFC 4122.
UUID objects are immutable, hashable, and usable as dictionary keys.
Converting a UUID to a string with str() yields something in the form
'12345678-1234-1234-1234-123456789abc'. The UUID constructor accepts
five possible forms: a similar string of hexadecimal digits, or a tuple
of six integer fields (with 32-bit, 16-bit, 16-bit, 8-bit, 8-bit, and
48-bit values respectively) as an argument named 'fields', or a string
of 16 bytes (with all the integer fields in big-endian order) as an
argument named 'bytes', or a string of 16 bytes (with the first three
fields in little-endian order) as an argument named 'bytes_le', or a
single 128-bit integer as an argument named 'int'.
UUIDs have these read-only attributes:
bytes the UUID as a 16-byte string (containing the six
integer fields in big-endian byte order)
bytes_le the UUID as a 16-byte string (with time_low, time_mid,
and time_hi_version in little-endian byte order)
fields a tuple of the six integer fields of the UUID,
which are also available as six individual attributes
and two derived attributes:
time_low the first 32 bits of the UUID
time_mid the next 16 bits of the UUID
time_hi_version the next 16 bits of the UUID
clock_seq_hi_variant the next 8 bits of the UUID
clock_seq_low the next 8 bits of the UUID
node the last 48 bits of the UUID
time the 60-bit timestamp
clock_seq the 14-bit sequence number
hex the UUID as a 32-character hexadecimal string
int the UUID as a 128-bit integer
urn the UUID as a URN as specified in RFC 4122
variant the UUID variant (one of the constants RESERVED_NCS,
RFC_4122, RESERVED_MICROSOFT, or RESERVED_FUTURE)
version the UUID version number (1 through 5, meaningful only
when the variant is RFC_4122)
def __init__(self, hex=None, bytes=None, bytes_le=None, fields=None,
int=None, version=None):
r"""Create a UUID from either a string of 32 hexadecimal digits,
a string of 16 bytes as the 'bytes' argument, a string of 16 bytes
in little-endian order as the 'bytes_le' argument, a tuple of six
integers (32-bit time_low, 16-bit time_mid, 16-bit time_hi_version,
8-bit clock_seq_hi_variant, 8-bit clock_seq_low, 48-bit node) as
the 'fields' argument, or a single 128-bit integer as the 'int'
argument. When a string of hex digits is given, curly braces,
hyphens, and a URN prefix are all optional. For example, these
expressions all yield the same UUID:
UUID('{12345678-1234-5678-1234-567812345678}')
UUID('12345678123456781234567812345678')
UUID('urn:uuid:12345678-1234-5678-1234-567812345678')
UUID(bytes='\x12\x34\x56\x78'*4)
UUID(bytes_le='\x78\x56\x34\x12\x34\x12\x78\x56' +
'\x12\x34\x56\x78\x12\x34\x56\x78')
UUID(fields=(0x12345678, 0x1234, 0x5678, 0x12, 0x34, 0x567812345678))
UUID(int=0x12345678123456781234567812345678)
Exactly one of 'hex', 'bytes', 'bytes_le', 'fields', or 'int' must
be given. The 'version' argument is optional; if given, the resulting
UUID will have its variant and version set according to RFC 4122,
overriding the given 'hex', 'bytes', 'bytes_le', 'fields', or 'int'.
if [hex, bytes, bytes_le, fields, int].count(None) != 4:
raise TypeError('need one of hex, bytes, bytes_le, fields, or int')
if hex is not None:
hex = hex.replace('urn:', '').replace('uuid:', '')
hex = hex.strip('{}').replace('-', '')
if len(hex) != 32:
raise ValueError('badly formed hexadecimal UUID string')
int = long(hex, 16)
if bytes_le is not None:
if len(bytes_le) != 16:
raise ValueError('bytes_le is not a 16-char string')
bytes = (bytes_le[3] + bytes_le[2] + bytes_le[1] + bytes_le[0] +
bytes_le[5] + bytes_le[4] + bytes_le[7] + bytes_le[6] +
bytes_le[8:])
if bytes is not None:
if len(bytes) != 16:
raise ValueError('bytes is not a 16-char string')
int = long(('%02x'*16) % tuple(map(ord, bytes)), 16)
if fields is not None:
if len(fields) != 6:
raise ValueError('fields is not a 6-tuple')
(time_low, time_mid, time_hi_version,
clock_seq_hi_variant, clock_seq_low, node) = fields
if not 0 <= time_low < 1<<32L:
raise ValueError('field 1 out of range (need a 32-bit value)')
if not 0 <= time_mid < 1<<16L:
raise ValueError('field 2 out of range (need a 16-bit value)')
if not 0 <= time_hi_version < 1<<16L:
raise ValueError('field 3 out of range (need a 16-bit value)')
if not 0 <= clock_seq_hi_variant < 1<<8L:
raise ValueError('field 4 out of range (need an 8-bit value)')
if not 0 <= clock_seq_low < 1<<8L:
raise ValueError('field 5 out of range (need an 8-bit value)')
if not 0 <= node < 1<<48L:
raise ValueError('field 6 out of range (need a 48-bit value)')
clock_seq = (clock_seq_hi_variant << 8L) | clock_seq_low
int = ((time_low << 96L) | (time_mid << 80L) |
(time_hi_version << 64L) | (clock_seq << 48L) | node)
if int is not None:
if not 0 <= int < 1<<128L:
raise ValueError('int is out of range (need a 128-bit value)')
if version is not None:
if not 1 <= version <= 5:
raise ValueError('illegal version number')
# Set the variant to RFC 4122.
int &= ~(0xc000 << 48L)
int |= 0x8000 << 48L
# Set the version number.
int &= ~(0xf000 << 64L)
int |= version << 76L
self.__dict__['int'] = int
def __cmp__(self, other):
if isinstance(other, UUID):
return cmp(self.int, other.int)
return NotImplemented
def __hash__(self):
return hash(self.int)
def __int__(self):
return self.int
def __repr__(self):
return 'UUID(%r)' % str(self)
def __setattr__(self, name, value):
raise TypeError('UUID objects are immutable')
def __str__(self):
hex = '%032x' % self.int
return '%s-%s-%s-%s-%s' % (
hex[:8], hex[8:12], hex[12:16], hex[16:20], hex[20:])
def get_bytes(self):
bytes = ''
for shift in range(0, 128, 8):
bytes = chr((self.int >> shift) & 0xff) + bytes
return bytes
bytes = property(get_bytes)
def get_bytes_le(self):
bytes = self.bytes
return (bytes[3] + bytes[2] + bytes[1] + bytes[0] +
bytes[5] + bytes[4] + bytes[7] + bytes[6] + bytes[8:])
bytes_le = property(get_bytes_le)
def get_fields(self):
return (self.time_low, self.time_mid, self.time_hi_version,
self.clock_seq_hi_variant, self.clock_seq_low, self.node)
fields = property(get_fields)
def get_time_low(self):
return self.int >> 96L
time_low = property(get_time_low)
def get_time_mid(self):
return (self.int >> 80L) & 0xffff
time_mid = property(get_time_mid)
def get_time_hi_version(self):
return (self.int >> 64L) & 0xffff
time_hi_version = property(get_time_hi_version)
def get_clock_seq_hi_variant(self):
return (self.int >> 56L) & 0xff
clock_seq_hi_variant = property(get_clock_seq_hi_variant)
def get_clock_seq_low(self):
return (self.int >> 48L) & 0xff
clock_seq_low = property(get_clock_seq_low)
def get_time(self):
return (((self.time_hi_version & 0x0fffL) << 48L) |
(self.time_mid << 32L) | self.time_low)
time = property(get_time)
def get_clock_seq(self):
return (((self.clock_seq_hi_variant & 0x3fL) << 8L) |
self.clock_seq_low)
clock_seq = property(get_clock_seq)
def get_node(self):
return self.int & 0xffffffffffff
node = property(get_node)
def get_hex(self):
return '%032x' % self.int
hex = property(get_hex)
def get_urn(self):
return 'urn:uuid:' + str(self)
urn = property(get_urn)
def get_variant(self):
if not self.int & (0x8000 << 48L):
return RESERVED_NCS
elif not self.int & (0x4000 << 48L):
return RFC_4122
elif not self.int & (0x2000 << 48L):
return RESERVED_MICROSOFT
else:
return RESERVED_FUTURE
variant = property(get_variant)
def get_version(self):
# The version bits are only meaningful for RFC 4122 UUIDs.
if self.variant == RFC_4122:
return int((self.int >> 76L) & 0xf)
version = property(get_version)
NAMESPACE_DNS = UUID('6ba7b810-9dad-11d1-80b4-00c04fd430c8')
NAMESPACE_URL = UUID('6ba7b811-9dad-11d1-80b4-00c04fd430c8')
NAMESPACE_OID = UUID('6ba7b812-9dad-11d1-80b4-00c04fd430c8')
NAMESPACE_X500 = UUID('6ba7b814-9dad-11d1-80b4-00c04fd430c8')
def uuid3(namespace, name):
"""Generate a UUID from the MD5 hash of a namespace UUID and a name."""
from hashlib import md5
hash = md5(namespace.bytes + name).digest()
return UUID(bytes=hash[:16], version=3)
def uuid4():
"""Generate a random UUID."""
from os import urandom
return UUID(bytes=urandom(16), version=4)
def uuid5(namespace, name):
"""Generate a UUID from the SHA-1 hash of a namespace UUID and a name."""
from hashlib import sha1
hash = sha1(namespace.bytes + name).digest()
return UUID(bytes=hash[:16], version=5)
guid3 = uuid3(NAMESPACE_DNS,x).__str__()
guid4 = uuid4().__str__()
guid5 = uuid5(NAMESPACE_DNS,x).__str__()
