Honeybee – Daylight Simulation not working & how to run Annual Glare Analysis
Hi everyone,
I’m working on a daylight simulation using Honeybee, but it doesn’t seem to work properly. The simulation runs with errors, and I don’t get any results or visual output, so I’m not sure what’s going wrong.
Also, I would like to perform an annual glare analysis, but I’m not sure how to set it up correctly in Honeybee. Could someone please explain or guide me step-by-step on how to do this?
I wanted to attach my file, but as a new member didn´t work.
Any help or advice(workflow) would be really appreciated!
Thank you in advance,
Diellza
Pattern1-2025-10-07.gh (204.3 KB)
that is my file
I suggest you check the samples component that has properly set up scripts for both the daylight and glare studies.
Cheers
