What is the default glazing construction for Honeybee/EP?
Simple question that surprisingly I couldn’t find easily.
Also, is there some way to get a multiwall polycarbonate glazing construction?
If not, fine, I can make one.
It’s a generic double pane window with a low-e coating that should almost always be changed to something that’s more sensitive for the climate (typically using the HB ConstructionSet by Climate component).
If you don’t want to use the Grasshopper components to deconstruct the construction and materials into their properties, you can see all of the default values in this file, which is typically in:
C:\Users\[USERNAME]\ladybug_tools\resources\standards\honeybee_standards
