Hello! I am trying to install the honeybee-energy API and while the installation said everything went successfully, when I run this command honeybee-energy --help, i get the in the end the following: AssertionError: C:\openstudio-3.6.0\bin is not a valid path to an openstudio installation.
Looking into the openstudio03.6.0 folder, I do not see a “bin”… just a PDF. My questions are:
(1) is this a problem? if yes, should I try to reinstall openstudio 3.6?
(2) i have openstudio-3.4.0 and this has a “bin” and an executable within it. could i use this instead?
Thank you for your help! Relevant screenshots attached.
