Honeybee Energy Plus "AdditionalStrings_" Error
Hey all,
I’ve been trying to run this file:
008_Honeybee%20EnergyPlus%20Simulation.gh
with this Rhino file:
4.6.3dm
and when running the simulation I got this error:
  1. Solution exception:global name ‘additionalStrings_’ is not defined
I tried reinstalling EnergyPlus (8.2.0) and run it again. No use.
Ideas???
Thanks
Shai
S,
You need to reinsert the HB_runEnergySimulation component. Seems to be that you updated the file using the HB_Update component. This usually works well, but when the the updated version of the component has more input/output items it doesn’t, even though it appears it was updated.
You can tell when you get errors like this one.
A,
Thanks! I reinserted the component and it worked.
I think your comment is useful to the rest of similar cases.
Thanks a lot!
