Hi guys,
I am learning to use honeybee by following Chris’ youtube tutorial videos (they are very wonderful tutorials, thank you Chris!). When I trying to run energy simulation on honeybee, weird things happens:
the readEPResult component works, but there are no outputs on cooling, thermal loads and thermal load balance data. From the tutorial video i guess these data should be in outputs;
and there are no html report created in RunEnergySimulation Component;
the readEPSrfResult component didn’t work and the error is as follows:
" Your simulation probably did not run correctly.
Check the report out of the Run Simulation component to see what severe or fatal errors happened in the simulation.
If there are no severe or fatal errors, the issue could just be that there is .eio file adjacent to the .csv _resultFileAddress.
Check the folder of the file address you are plugging into this component and make sure that there is both a .csv and .eio file in the folder. "
I look into the folder and I sure the .csv and .eio file are there.
I think got everything the latest version, so i wonder what is wrong?
Thank you very much in advance!
GUO
test-1.3dm (103 KB)
test-1.gh (593 KB)
CHN_Guangdong_Guangzhou.592870_CSWD.epw (1.69 MB)
