Hello everyone! Honeybee reports that he lacks Energyplus v.8.1.0.
I looked for the Windows version on the github site, but I only find the Linux and Mac versions. Could someone help me?
Thank you!
This question has been asked before. Do you have to use this version? Why don’t you use a newer version of EnergyPlus? Or simply use OpenStudio which will also install EnergyPlus for you.
@mostapha I have already installed Openstudio, but Honeybee keeps telling me that it’s missing Energyplus v8.1.0, so I think I have to install that version of Energyplus. I initially installed the latest version, but Honeybee was not working.
@Fra29, according to my knowledge there is no version limit for OpenStudio to be installed. The OpenStudio you have installed could be the older one with EnergyPlus version 8.1 requirement. Try to uninstall your existing OpenStudio and install the new version. I would recommend the destination folder for Installation be in C:\openstudio-[your version] such that the Honeybee can recognise the EnergyPlus folder in it.
Additionally, install your pending Windows updates if any.
@Naga I already have the latest version of Openstudio and it is saved in the right folder, but the program keeps asking me for Energyplus v8.1.0.
I don’t understand how to fix it. I tried to follow all the old discussions and advice about it, but the program still doesn’t work properly.
@Fra29
Do you have OpenStudio 3.0+ installed? It doesn’t work with current ladybug legacy version yet. You will need to install OpenStudio 2.9 instead.
@MingboPeng I tried to install OpenStudio 2.9, but Honeybee keeps asking me about Energyplus v8.1.0.
@MingboPeng Oh thanks! Then it’s not me, but it’s my teammate’s file that doesn’t work. He has the old version and I have the latest one, so when I open it the components don’t work.
Thank you so much for your patience!
I have the same problem. I don’t know how to update the plugin. How did you updated it?
I re-downloaded the correct version from this site!
@MingboPeng Can I install two versions of OpenStudio on my pc?
I need a surface-by-surface method (legacy LBHB) simulation with OpenStudio 2.9, and the latest OpenStudio 3.3 for other simulations but not at the same time.
For my case, I have these on my machine according to my Compatibility Matrix.
rhino 7
python 3.7.9
radiance 5.4a
openstudio 3.3.0
energy plus 9.6.0
But it gives me an error when I try to run the example file from hydra .
Could you please tell me where can I get OpenStudio 2.9 if I need to install?
Thank you very much!~
Hi, I am having a similar problem here. In my case I have the Legacy components installed and OpenStudio 2.9.1, and Honeybee cannot find it. Previously I had also OpenStudio 3.0. installed and didn’t work.
Not sure how can I solve this…
Thanks in advance
Just use a version of the plugin that isn’t 7 years old. There are plenty of much newer and better versions available on Food4Rhino.
