Hello Everyone,
is there a proper way to assemble an EPConstruction for a rear ventilated facade?
I didn´t find an air material, while composing, except for the window air material and the airwall material, which don´t seem to be the right choice.
Best regards,
Dominik
There is one air space material in the HB material library. Of course you can also add your own.
Mhhhh and if i wanted to simulate this kind construction in THERM; what would be the material of choice?
When I input the default air space resistance of honeybee i recieve the warning, that it has a conductivity of 0. Where it schould be something around 0.025 or 0.076921 according to this thread:
http://www.grasshopper3d.com/group/ladybug/forum/topics/therm-examp…
But the custom made THERM material doesnt seem to be the right one either because as far as I understand it is only useful for windows constructions while setting the cavity model?
Is there some way to set up a material for a ventilated air space as part of a rear ventilated facade?
Best regards,
Dominik
Look at hydra examples like this one and this one (look for the “frame cavity” material).
Thanks again
I thought this would only suit for window constructions.
