Hi
I keep getting this error in my script (1. Solution exception:‘EPZone’ object has no attribute ‘cenPt’), anyone had this error and know how to fix it? Everything is up to date as well.
I’m a new member to forum so it won’t let me attach my script…
Hi @Kurtis_w
Welcome to the forum!
Probably it has to do with the daylight setpoint in combination with L-shaped rooms. In those cases the centrepoint lays outside the zone.
More information you can find on this forum just by searching on:
"1. Solution exception:‘EPZone’ object has no attribute ‘cenPt’ "
