Can somebody share a gh example that uses HB[+] in an annual simulation including two windows with dynamic blinds with 2 or more states each, and how the results are processed? I wanted to understand the workflow in HB[+], how to set them and how to process results by changing state for each hour of the year for each window. Thanks.
Thanks @Teja5zz for kindly sharing this. However this is a Honeybee Legacy workflow (daysim etc), not a Honeybee Plus (HB[+]) workflow.
According to communication with @mostapha, modelling the blinds geometry explicitly is currently a limitation, but it is under development and will be possible in the next release
Hi @Aliarch, I did not look for any example since my last comment as I did not have a relevant project since then. It may be possible in a newer version, but I haven’t looked. Good luck!
