Honeybee falsecolor & imageviewer without legend
I was also wondering how to put the legend on the image, would anyone could help with that? My Radiance version is 5.2.2 and I have seen some post that using newer version, but I would assume this version should be working fine.
But I got the same image showing as above without a legend.
Hi @David1 and @liboY ,
The archaic version of Falsecolor2 that we used in the Legacy plugin has the “legend generation” step broken in it. So I think you won’t be able to get a legend in Legacy even if you wanted to.
If you want to be able to produce Falsecolor graphics that include a legend, you should use the latest LBT 1.4 plugin, which uses the Falsecolor utility that ships natively with Radiance 5.3 and above. You see that we don’t have any issues getting legends over there:
Thanks Chris. Got it.
