I tried to run the cumulative sky component but it is not working…
Hi @stefaniab,
I’ve managed to solve a similar issue in the past by also copying the GenCumulativeSky.exe
file that devang posted, to the following folder:
C:\Users\<username>\AppData\Roaming\Ladybug\
When you try to use the cumulative sky grasshopper component it should automatically download it in that folder, but maybe due to some reason that’s not working.
Hope it helps.
Hamza
