I want to test the exterior thermal comfort by testing different scenarios using (honeybee 1.6):
- The room has 1 green wall
- The room has 1 Green wall and a green roof
- The room has 1 Green wall, a green roof, and is surrounded by green ground.
I keep getting the same error when I connect the green roof and/or the green ground to the model. What should I do to fix this issue? also, is this the right way to test green roofs and walls, or there is a better way?
Green roof, ground and wall.gh (92.3 KB)
