Honeybee Grid Map appears Hexagonal
I am trying to visualise the result of HB Annual Daylight receipe by Plugging in the DA into the heatmap with mesh from sensor grid but the mesh appears hexagonal on all grid points. How can i make it a uniform rectangular mesh?
You are probably using the wrong component (HB radial grid from room) to generate the test grid. I think the one you are looking for is “HB sensor grid from room”.
Best
Matteo
Thanks Matteo, that was really helpful.
