Hi all, I wanted to simulate the energy consumption of an office building, but ran into problems with the HVAC setup. After I used the VAV air conditioner and set the work schedule, the simulated energy consumption did not seem to work according to the work Schedule I set. The air conditioning system is running all year round, which means that the working schedule I set did not work, what is the reason for this? How should I set the work curve to actually control the VAV system? In addition, because I simulate the building in China, its air conditioning parameters and ASHRAE has a certain difference. In Ladybug Tool 1.6 or 1.7, is there a way to set your own air conditioning parameters?
Thank you so much!
question1016.gh (640.1 KB)
