Hello all, I have recently formatted my computer so i had to go through re-installing everything again, and my Honeybee doesn’t seem to find open studio, although it is installed directly in C:/, is there a way to link it to it? which directory should it be installed in?
Thanks
Please connect Honeybee_Honeybee component to a panel, upload that messages.
Try to install OpenStudio in default path without changing that:
C:\Program Files\
best,
Omid
Hey Omid, so i did the following
Uninstall OpenStudio from C:\ (although this was the default suggested location)
Remove Ladybug and Honeybee using this http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&…;
Restart my pc
Reinstall OpenStudio in C:\ProgramFiles
Reinstal Ladybug and Honeybee
still same error message
Gabriella,
From your screenshots, You reinstalled EnergyPlus, not OpenStudio!
If you don’t have OpenStudio download it from below link and install that:
OpenStudio
and read Installation Instructions .
best,
Omid
woops, must have mixed up the links while installing…
Thank you both for your patience, the bee is flying
Best
Gabriella
Hadeer
November 25, 2023, 10:21pm
6
Hello, I have the same error despite having the latest version of OpenStudio and OpenStudio Application installed, Any Clue?
