Honeybee is still not fly
As a result of all my research I have installed Openstudio and Energy Plus and all necessary programs such as Daysim and Radiance. But still honeybee is not flying. The programs I have installed are shown in the attached file. Is there a problem with the location of this files ? When I started Openstudio, it warned that “could not find or download Openstudio result measure”. Is this the main reason for the problem? How can I solve it? Could you help me please?
P.C.: Rhinoceros 5, OpenStudio-2.5.0.
Thank you so much…
Meryem ALAGÖZ
First thing i’ll do is updating LB and HB. Using 2016 verion is TOO old and probably is not recognizing your installed OS.
Thank you so much. I’II try ubdating LB and HB. I have to finish my study on Monday. So, I there is no other simple way you know, isn’t it?
Updating is the simplest and fastest solution.
Ok…I did it and I solved the problem… Thanks :slight_smile:
