I met a promble when I installed honeybee.It always warns that Failed to find the ALWAYS ON in honeybee schedule library and lots of errors about schedule library.I’m sure I have installed all the components because what I installed are all copied from my classmate who can use it nomally.So what should I do? In addition,the honeybee example can run successfulliy in my classmate’s computer.
Hi,Huang
I met the same problem with you ,and I can`t solve it now ,so could you please tell me how did you solve it or are you still have this problem?
Hi ,devang
Thanks for the quick response.In fact ,I have fit the problem just now ,it seen like something wrong with Openstudio .And I download a new ‘OpenStudioMasterTemplate.idf’ on github and replace the old one in my ladybug default folder ,and then I solve the problem.
HI everyone.I am about new using honeybee/ladybug.I’m trying to model a simple model in honey bee.when I attached the required objects to the EP simulation the component gets red,the main issue is that program failed to find occ and also other types of schedules in the library.I’m not sure but think that there isn’t any schedule in my honeybee library, I also downloaded the suggested files in another topics but still have the problem.how can I solve the problem pleas?
Thank you minggangyin.I downloaded all the files you mentioned and copy them but the error still exist .I creat schedule in honeybee and connect it to the component so lot of errors disapared but 3errors remained.and actually there is also a question remained for me that when I download some files such as measure,zip folder should I copy each file in the path seprately or just the whole folder cause the errors exist.
Hi.Thank you minggangyin.yes I use energy pluse 9.2 and open studio 2.9.thank you for your guidence.I have a pack of Energypluse 8.7 and I’ll download the 8.8 one and the 2.5 of openstudio.
