Honeybee & Ladybug out
H
Hello All,
Could you please check the attached picture to see why honeybee and laduybug (OUT) rather than Vviiiizzzzz ? Is there is any problem ?
Regards, Loulwa
This should be a Grasshopper settings somewhere that changes the output name to default. You shouldn’t be worried about that.
Thanks Great Mustapha
Hi - FWIW, it looks like you might have right-clicked and toggled the display of the “out” parameters.
When I disable “Show” and then re-enable it again, the output changes to “out”. When I drag in a new Ladybug component, it reads the default “Vviiiizzz”.
At any rate, as Mostapha said, nothing to worry about…
-wim
Please Could you tell me what the wrong ??
I tried many times to find the error and I can not
@loulwa For better understanding share your file to check the issue.
test.gh (547.7 KB)
Attached the file
