Here’s what it shows
- The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][day_of_week_for_start_day] - “31” - Failed to match against any enum values. - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][number_of_times_runperiod_to_be_repeated] - Value type not permitted by ‘type’ constraint. - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][use_weather_file_daylight_saving_period] - “Monday” - Failed to match against any enum values. - The simulation has failed because of this fatal error:
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
I don’t know what go wrong and ask for help!thank you!!
