HoneyBee OpenStudio - Solution Exception: Failed to translate model to OpenStudio
Hi @PHExplorer , @gregb
I just ran the ‘LB Versioner’ to update to v1.8.115, and installed OpenStudio 3.9 (as per the compatibility Matrix), and I can confirm that this is now causing a Failed to translate Model to OpenStudio error on MacOS.
Environment:
  • Apple M1 Max (2021)
  • MacOS Sequoia 15.5
  • Rhino v 8 (8.21.25175.17002, 2025-06-24)
  • LBT Version 1.8.115
  • OpenStudio v3.9
@chris , do you have a suggestion for how to track down where the error is occuring?
thanks!
@edpmay
Example File:
