Hi forum, new Grasshoppper user here. When running the peak load I get an error when press simulation, this is a “database is locked” error. A snap shot of the full error is below attached. Would really appreciate the help.
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.audit
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.bnd
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.dbg
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.eio
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.err
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.eso
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.mtd
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.mtr
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\eplusout.sql
Failed to remove C:\Users\ALADILA\simulation\Peak_Loads\sqlite.err
Runtime error (PythonException): database is locked
Traceback:
line 693, in _extract_zone_sizes, “C:\Program Files\ladybug_tools\python\Lib\site-packages\ladybug\sql.py”
line 160, in zone_cooling_sizes, “C:\Program Files\ladybug_tools\python\Lib\site-packages\ladybug\sql.py”
line 179, in find_max_cooling_des_day, “”
line 210, in check_and_filter_des_days, “”
line 340, in script
