I have a regular problem and couldn’t fix it. Can anyone help? 15 of these problems and unfortunately I can’t send the file to u.
- The simulation has not run correctly because of this severe error:
** Severe ** Line: 3360 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 3360 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 2.4000000953674316; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 3361 Index: 19 - “2.4000000953674316” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 3385 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
