Hi guys,
I’m doing some experiments with the Daylight Factor Simulation component to calculation time and results sensibility to radiance parameters. I’m feeding it with custom radParameters as seen below:
The comand prompt window (see attached image) seems to put -ad 1000 as default even if it seems to be set to 512 in grasshopper. In contrast to -ad, the modification of -ab to 3 has been taken into account.
Have you set minimum values for RADparameters? If yes, would it be possible to force them to custom values?
Thanks in advance for your help
Best regards,
Aymeric
