Yeah… Version 1.2.3 but why isnt the issue resolved when i am using a new version of Radiance, it seems that its an issue with finding Radiance in the Core Libraries.
Are you sure that the the “HB Check Versions” component indicates that you are using the new Radiance? Also, are you sure that your core libraries are up-to-date on your machine? I recommend running the “LB Versioner” component just to be sure
