Hi again @sarith,
here is a model that I am testing. I’m examining 560 points on my facade that is based on a 3x6m grid.
Thank you for the additional information, although I’m using the Honeybee Legacy “Run Daylight Simulation” this one https://rhino.github.io/components/honeybee/runDaylightSimulation.html. And as far as I know it should be based only on rtrace simulation only so I am a bit confused when it is okay to mix these different settings of different functions.
To the link you sent with the analysis parameters, there’s this sampling parameter -c. Is that comparable with any other parameter from rpict or is that only for the purpose of a 2-3-4-phase methods?
Thank you very much! Ondrej
