Honeybee result comparison
hello everyone
i am trying to measure eui of a generative model in honeybee and i want to compare honeybee result with DesignBuilder but i have problem to match hvac. i dont know how to define idealairload in DesignBuilder.
is it possible to help me please.
This seems a question for DesignBuilder.
Thanks for your reply I need some details about idealairload
As @MingboPeng said, you should ask the people who know more about DesignBuilder your question about modeling Ideal Air Load system in DesignBuilder. There is a much higher chance that someone can help you on their forum.
Thanks for your reply i will do that :pray:
I can suggest watching this video
And using their help website
thank you so much :pray:
@Mehr
For comparing results between tools (DesingBuilder, EnergyPlus, Honeybee).
I could also recommend the BESTEST (building envelope and fabric load tests)
methodology from ASHRAE 140 standard. It will be very helpful for validating the results.
Both DesignBuilder and Honeybee use the same engine EnergyPlus,
export both models to .idf files and compare them.
BESTEST Honeybee , BESTEST other tools
its great i will check it thanks :rose:
I probably could have uploaded this earlier, but it is better later than not at all? :smiley:
When I was studying I had a project where I did the bestest cases 600 and 600FF between EnergyPlus and DesignBuilder. You can do the same comparison between Ladybug Tools and DesignBuilder.
You can find the pdf document and related idf and dsb files in this location.
