Honeybee_Run Daylight Simulation
Hello friends
What component should I use to enter month, day and hour in this simulator? So that I can observe the change in brightness at different times. Thanks
What you are attempting is an annual simulation. The time control is available in point-in-time analysis. You can use grid based recipe for that.
