Hello friends
I get a different number when simulating daylight, with each turn on and off.
For example, 875 lux, 880 lux, 888 lux!
Where’s the problem? And can the numbers extracted from this simulator be scientifically reliable?
Hi,@Aliarch As for my experience, it is a normao result. Because Radiance used monte carlo method to run daylight, it will be a little different for every calculation. You can refer to this website:
https://floyd.lbl.gov/radiance/refer/long.html
