Hi the Honeybee simulation is not running with this error message
The same model is running in another system
I thought may be an issue with my model and just made a simple box and did run the simulation even then the same error.
- The simulation has not run correctly because of this severe error:
- Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_method] - “AverageOverDaysinFrequency” - Failed to match against any enum values.
- Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_update_frequency_method] - “30” - Failed to match against any enum values.
- The simulation has failed because of this fatal error:
- Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
