Honeybee Runtime Error: Win32Exception
Hello
I am having a problem running honeybee and I see an Runtime Error; Win32Exception.
The problem started when I uninstalled HB/LB and reinstalled the new version, and now I am getting the error.
From Radaince, Eplus and OpenStudio, I ONLY re-installed OSM again to save it in C:\program files rather than the automatic location that it selects. My radiance and Eplus are the same old ones.
My radiance is located in C:\radiance
OpenStudio is in in C:\program files\Open studio
EnergyPlus is in C:\EnergyPlus V8.5
I read a previous post about this error but that did not solve my issue.
http://www.grasshopper3d.com/group/ladybug/forum/topics/honeybee-ru…
In another example file from Hydra, when I connected a panel to my Honeybee component, I saw:
Failed to sort OpenStudio installation folders. I don’t know if that is the same problem or not.
Would you please tell me what could be causing this error?
I appreciate your help.
Ladan
Hi Ladan,
Did you check c:\ladybug folder? Is the folder created? This error happens when Windows cannot create or write to a folder. What happens if you change the defaultFolder_?
Mostapha
Hi Mostapha
Thanks for your response. I do see C:\ladybug on my computer.
I feel that it is because of my OpenStudio or EnergyPlus because I can see daylighting results but not energy simulations.
I read on other discussions that OpenStudio should be in C:|program files and since it automatically wants to be located on C:\OpenStudio, I created a folder myself in C:\program files and called it OpenStudio and saved the openstudio documents there while installing.
In regards Eplus, I have had all versions including V-8.3 and V-8.5 before re-installing LB+HB. HB picks V-8.3 automatically. I don’t know if that could be a problem too.
Please help me to get these bugs fly again!
Thanks
Ladan
Hi Ladan,
Can you please try C:\EnergyPlusV#### and C:\openstudio-###?
Following are directories on my machine. They work perfectly.
C:\EnergyPlusV8-5-0
C:\openstudio-2.1.0
Thank you very much Devang!
the problem was that I installed OpenStudio 2.2 and it did not work. now I have OpenStudio 1.12 and it is working fine!
thanks again
Ladan
Hi Ladan
I have the same problem,
I installed the older version of E+, but I can’t find the Openstudio version 1.12 on the internet. Can you tell me where did you find it please ?
Thanks
Hi Hosna,
Here’s the link to Openstudio 1.12 as referenced here.
Thank you Anton :slight_smile:
