I want to calculate the the percentage of the room area on which an illuminance of 300 lux is recorded for at least 50% of the daylight hours of the year.
I am using the annual daylight component and the sDA component.
When I consider the default value for the target time (50% as indicated in the explanation), I obtain an sDA value of about 8%.
However, when I provide the target time as 50%, the result is totally different and I obtain an sDA value of about 60%.
Attached are the two images of the sDA component (with default value and custom value).
Moreover, I attach the image of the whole workflow.
I am a bit confused about the sDA component and the calculation of the sDA value, can you please help me?
Thanks in advance for your help,
Erika
